Disables the OSPF process for the router.
This command has no keywords or arguments.
N/A.
Not applicable.
The following command disables the OSPF process for the router:
disable ospf
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
